Replace Catalytic Converter
Old Mar 9, 2012 | 09:20 PM
tmizzle's Avatar
Default Replace Catalytic Converter
Does anyone have the "How to" in replacing the catalytic converter on a 2004 Chrysler Sebring LX 2.7 L? Also, is this a project that I should be trying myself as a DIY? Thank you in advance.
Old Mar 9, 2012 | 10:21 PM
tmizzle's Avatar
FYI: I have the engine error code 0420 and I have a Massachusetts state inspection in 2 weeks. I doubt the issue will pass the inspection.
Old Mar 9, 2012 | 11:02 PM
There are other things to check before replacing the catalytic converter. This code could be caused by a problem with the O2 sensors. It's set when the readings from the O2 sensors are too close together, which can be caused by replacing one without replacing the other because they "age" together.
That rear cat (bank 1) is a PITA because it won't come out even if you unbolt it completely. I think you need to also remove the rear engine mount.
There's a photo album on the forum here showing how to remove the crossover pipe that also discusses unbolting the rear cat since it's necessary to pull out the pipe, which is also necessary to remove the cat.
I hope that makes some sense.
Old Mar 10, 2012 | 08:36 PM
tmizzle's Avatar
I will double check the sensors before I even think about the catalytic converter. As for the gallery you mentioned, I found it and it is helpful. Thank you.
pupy
Feb 23, 2012 01:54 AM
chrycon
May 24, 2011 01:54 PM
msarles1
Apr 16, 2011 10:27 AM
ymitchell7
Feb 6, 2011 04:45 PM
scfcarla
Feb 9, 2009 12:36 PM
