Sebring TMS error or reset
Old Mar 15, 2009 | 08:06 PM
Tony H's Avatar
Cool Sebring TMS error or reset
Hi - I have a 2008 Sebring Touring and after having a puncture repaired the TMS warning "chimes and says the tire that has been repaired has 0 PSI air, this is intermittent and can happen after some hours of driving, is the sensor faulty or is there a reset that can be done.
TH
Old Mar 15, 2009 | 09:35 PM
did u replace the tire? if so who ever did it could have damaged the sensor.
Old Mar 15, 2009 | 10:36 PM
Tony H's Avatar
Post
Where is the sensor actually located - is it in the Tire valve or on the rim somewhere?
Old Mar 16, 2009 | 07:05 PM
all u would see would be the valve stem the rest is behind the rim. they get broken all the time by the people that don't know anything about them.
Old Mar 18, 2009 | 09:40 PM
mwstant's Avatar
if the tire was taken off the rim then it could have been damaged during dismounting or mounting. There isn't normally an intermittent warning if its done properly. I would take it to the dealer and see if they can read the sensor if not then you need to take it back to the place that fixed it and get them to reimburse you for a new sensor which can be anywhere from 20 to 250 dollars a piece. depending on the type of sensor and what not. I will look it up tomorrow at work and let you know when i get off.
1OLDMAN
Oct 8, 2019 01:54 PM
zipdrive
Jan 16, 2012 01:27 AM
zimba
Jun 10, 2007 09:50 PM
bobby26
Mar 20, 2007 04:17 PM
cwinship
Dec 13, 2006 03:34 AM
