Tachometer not work correctly
Old Apr 13, 2011 | 09:47 PM
stew88fan's Avatar
Default Tachometer not work correctly
The Tachometer in my 1998 sebring convertible 2.5 jumbs from 1 rpm to 4 rpm randomly or sometimes works backwards anyone have an ideal what might be wrong
Old Apr 14, 2011 | 12:21 PM
2003sebring's Avatar
Don't know if your model has this or not but run a test on the instrument cluster.
YouTube - Chrysler Sebring 2003 Test Sequence
That way you can see if you have a bad gauge or something is bad in the engine.
Is it just the gauge or are there corresponding reactions coming from the engine when the gauge is malfunctioning?
If it is just the gauge, it should be relatively easy to replace.
I had a bad camshaft position sensor that had ill effects on my rpm. May be you should look into that?
Old Apr 15, 2011 | 04:18 PM
stew88fan's Avatar
Default Tachometer not working
Ya I tried the instument panel test didn't help. I don't feel any problems with the engine just the tach.
johnpvb
Apr 16, 2014 09:44 AM
earleb
Feb 14, 2014 03:07 PM
dubs0587
Sep 19, 2010 11:31 PM
dhhbomb
Jul 14, 2010 08:39 PM
brad
Nov 21, 2006 06:40 PM
