trans problem!!!!
Old Nov 16, 2011 | 11:54 AM
Motor_man's Avatar
Default trans problem!!!!
Hey guys have a trans problem on a 2001 chrysler sebring 2.7 eng trans will not shift out of low 1 (have to pull over turn car off restart sometimes trans will shift after that have a 0700 code &0605 code any advice would be helpfull!!!!! trans does not slip,trans fliud full,was thinking it could be trans control module THANK,s JAMES EAGAN
Old Nov 16, 2011 | 05:38 PM
605 is internal trans controller
Old Nov 19, 2011 | 11:40 AM
LeoM's Avatar
My 99 did the same thing and all it needed was to replace the vehicle speed sensor.
Old Nov 23, 2011 | 02:46 PM
Motor_man's Avatar
Thank's for the info i'll check the speed sensor
Old Nov 23, 2011 | 05:39 PM
I might as well give up this gig its like talking to brick walls here most of the time. Do i not have any pull around here being a Chrysler tech for 15 years?
Symptom:
P0605-INTERNAL TCM
POSSIBLE CAUSES
TCM - INTERNAL ERROR
TEST ACTION APPLICABILITY
1 If there are no possible causes remaining, view repair. All
Repair
Replace the TCM. WITH THE DRBIIIt PERFORM QUICK
LEARN AND REPROGRAM PINION FACTOR.
Perform 41TE TRANSMISSION VERIFICATION TEST - VER 1.
Old Nov 23, 2011 | 06:40 PM
TNtech's Avatar
I know right? LOLz
Old Nov 25, 2011 | 12:59 PM
Motor_man's Avatar
Default Another brick in the wall
Originally Posted by TNtech
I know right? LOLz
Thank's for the great info/ you have been a big help!!!!HAVE A GOOD ONE!!!
parlayjay
Apr 18, 2010 03:28 AM
sosomechanic
Nov 25, 2008 08:36 AM
continental777
Mar 14, 2008 03:47 PM
shibasmom
Jan 30, 2008 10:44 PM
erik
Dec 13, 2006 10:37 PM
