windows auto down, but not auto up
Old Oct 8, 2021 | 07:54 PM
Jayson44's Avatar
Default windows auto down, but not auto up
08 convertible here, and my windows auto-down just fine, but they won't auto-up. I thought I read online to hold the windows in the up position to get them to reset and do the auto-up, but it's not working for me.
is there a way to accomplish this? or instructions to do so? maybe I was reading the wrong instructions...
J.
Old Oct 9, 2021 | 11:55 AM
ggoose's Avatar
Are you referring to the windows motoring up after the top is closed? You need to to hold the top closed a bit longer and the windows will motor up while you hold the top closed button.
Outside of holding the top closed button, I am not aware of any other window auto-up feature.
Old Oct 9, 2021 | 01:59 PM
Jayson44's Avatar
no, that works just fine. I'm just referring to rolling the windows down normally. they go down auto if you push all the way down. but when you pull all the way up to bring them up, they don't come up automatically. but it feels like there is an extra "step" when pulling up as if the auto-up functionality is there but not working.
J.
Old Oct 10, 2021 | 08:56 AM
When all else fails, try reading the owners manual. Not entirely sure about that model year but I doubt that "auto up" was a feature then.
Old Oct 10, 2021 | 10:55 AM
Jayson44's Avatar
that's what I was wondering, but there is definitely an "auto up" extra click to the switches. like, you can pull up on them in the normal setting (middle) and they go up, but you can pull up more and it will *click* past the middle setting the way it does when you put them down. that's why I asked.
J.
Old Oct 10, 2021 | 01:10 PM
cjb108's Avatar
J.
Having read through this thread, I believe that the extra "step" that you feel could be the switch position used when the windows motor up after the top has been completely closed
Old Oct 11, 2021 | 02:17 PM
If you don't have the owners manual, download it from chrysler.com.
Old Oct 6, 2022 | 09:30 PM
Staton17's Avatar
Default Window
I have the same problem but my back passenger window won't go up with switch but will go up with convertible operatik. Switch..just started..any idea?
Old Oct 7, 2022 | 08:47 AM
It could be the switch itself, but the more likely culprit is the wiring harness where it goes between the body and the door. With the flexing that happens every time the door is opened and closed, you can get a broken wire right there. Might want to check that out.
vedubw
Mar 7, 2018 09:26 AM
footballderrick
Jan 25, 2018 07:01 PM
chipy66
Jun 13, 2013 05:30 PM
discostu
Sep 28, 2012 04:55 AM
KYBarrister
Mar 19, 2009 09:09 PM
