08 300C 5.7 RWD / ABS EPS Traction Control Warning Lights
Old Jan 2, 2021 | 05:54 PM
300C Ya's Avatar
Default 08 300C 5.7 RWD / ABS EPS Traction Control Warning Lights
Hello All,
Ihave a 2008 Chrysler 300C 5.7 RWD, The ABS EPS , Traction control & Check engine lights are on, .I'm not sure if they came on after I pulled a small mini cooper 200ft out of an intersection. using a tow rope hooked to my hitch..
After reading others threads recommendations
This is what ive done so far to fix....
Replaced rear wheel Hub
Replaced front and rear ABS & Speed Sensors..
Checked fuses..
Fully Charged Battery
Tried resetting system. pulling terminals off batteries for an hr. Still on..... AAAHHHHHH,,,lol
Cars overdue for inspection,
Any recommendations would be greatly appreciated.
Old Jan 2, 2021 | 10:17 PM
JWhitley's Avatar
You will need to have it scanned to see exactly what the codes are to see what is causing the issue .Hope this helps .
Old Jan 3, 2021 | 01:52 PM
300C Ya's Avatar
I will follow up soon.
Waiting on OBD Scanner just ordered..Should arrive Wends. .
FOXWELL NT510 Elite Bidirectional Scan Tool for Chrysler Dodge Jeep, Full System HVAC 4WD Obd2 Scanner with ABS Auto Bleed Battery Registeration TPMS EPB DPF Service Light Maintenance Functions etc
https://www.amazon.com/gp/product/B07XK1P8ZT/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Should of searched threads of which OBD scanner to order... Hopefully this one will work. The last one I tried said it supported my car, but didn't support the ABS function.. Returned it.
How often is it actually the ABS Control module that is bad.... will a code show a bad ABS module?
Old Jan 5, 2021 | 08:26 PM
300C Ya's Avatar
OBD Came a day early....1 Active code.... C102B Right Rear Wheel Speed Sensor Circuit. Have to check if the new one I put in....is bad.. or maybe dirt got onto it when i installed.....
Old Jan 5, 2021 | 08:50 PM
ggoose's Avatar
This link discusses the c102b code - https://www.chargerforums.com/thread...-clear.284873/
Old Jan 17, 2021 | 05:44 PM
300C Ya's Avatar
Fixed it with a new speed sensor... ABS, Traction Control, BAS, Lights went off after clearing the codes.
I put the new speed sensor in, turned the car on, now the brake light was on to. Thought I was going to run into the same problem... not being able to clear the codes with the scanner
But when I plugged the OBD in and scanned it, The sensor code came up stored. not active. What a relief. I cleared the stored codes. and poof.. all those trouble lights went off.
Old Jan 18, 2021 | 06:55 AM
tarhealcracker's Avatar
Good on you for letting us know how it sorted out..
billbon8
Aug 5, 2022 12:25 PM
JoAmps
Apr 6, 2017 10:31 PM
dalivision
Mar 1, 2017 10:22 PM
biggerblues
Aug 22, 2012 08:41 AM
blong
Mar 31, 2008 10:15 AM
