2.7L V6 Question
Old Jan 17, 2021 | 11:11 PM
nonrabbit's Avatar
Default 2.7L V6 Question
Hoping that someone can provide some insight into the sludge issues with the 2.7L V6 engine. Is there a recommended oil change frequency, oil change type/brand or additive that can help to prevent the sludge buildup? I watched a video on YouTube that recommends JilCat Proline Gas Engine Conditioner. Anyone have any experience with this? Thanks in advance.
Old Jan 18, 2021 | 07:00 AM
tarhealcracker's Avatar
Sludge build up in modern engines is not usually a function of the oil assuming you are using a quality oil. I suspect water is getting into your engine. Blown head gasket ?
Old Jan 18, 2021 | 10:32 AM
ggoose's Avatar
The 2.7l sludging problem is mostly related to the pcv system (note there are some that will take issue with this cause). There were running changes made in the system from 2001 to 2004. The issue was pretty much resolved during the 2003 model year with 2004 being fully resolved. It is noted on a number of chrysler forums that using synthetic seems to significantly reduced sludging for the 2001 and 2002 model years and changing the oil before 6K miles. If using conventional oil, 3K miles would be tops for an oil change.
Note I had a 2004 2.7l with 240K miles, using synthetic and changing around 8k miles. Only motor issue I had was the water pump needing to be replaced at 135K miles. Tech noted the motor was very clean under the timing chain cover.
Old Jan 18, 2021 | 04:05 PM
Pretty close GGoose but in this matter of the 2.7 the early builds had smaller oil passages which the API grade GF1 was not working well in them SO in 2002 the new grade GF2 fixed the restriction flow in the smaller oil passages in the 2.7 area. Other automakers had the same kinda issues with the grade GF1 oil there for there was an industry standard change to correct that issue. Now we are up to GF5. SO unless you just dont change you oil at all the sludging issues is pretty much gone away.
Old Jan 19, 2021 | 05:39 AM
Wow. Awesome responses from our crew.
Kevin - is the GF5 standard marked on the oil container/can ? For instance is Mobile 1 a GF5 oil ?
Old Jan 19, 2021 | 07:12 PM
should be where it says API thats the grading system look slike GF5 is now gone may of 2020 GF6 now
GF-6A Current Introduced in May 2020, designed to provide protection against low-speed pre-ignition (LSPI), timing chain wear protection, improved high temperature deposit protection for pistons and turbochargers, more stringent sludge and varnish control, improved fuel economy, enhanced emission control system protection and protection of engines operating on ethanol-containing fuels up to E85. GF-6B Current Applies only to oils having an SAE viscosity grade of 0W-16. Introduced in May 2020, designed to provide protection against low-speed pre-ignition (LSPI), timing chain wear protection, high temperature deposit protection for pistons and turbochargers, stringent sludge and varnish control, improved fuel economy, emission control system protection and protection of engines operating on ethanol-containing fuels up to E85. GF-5 Obsolete* Use GF-6A where GF-5 is recommended. GF-4 Obsolete Use GF-5 where GF-4 is recommended. GF-3 Obsolete Use GF-5 where GF-3 is recommended. GF-2 Obsolete Use GF-5 where GF-2 is recommended. GF-1 Obsolete Use GF-5 where GF-1 is recommended.
Old Jan 19, 2021 | 07:27 PM
nonrabbit's Avatar
When I look at the spec of Castrol GTX 5W30 it states that it is API SN, GF-5. Should I be looking for GF-6A or GF-6B for better sludge protection?
Old Jan 20, 2021 | 05:28 PM
nah GF5 works just fine it was in uses for many years like windows constant updates lol
Old Jan 31, 2021 | 07:32 PM
waagh2deth's Avatar
Lightbulb
Have an 06 2.7l 300 going on 200k+ miles. I change it at every 3500 miles- I'd say that's a fair interval. I would not go over 5k per oil change, just asking for trouble
Old Feb 1, 2021 | 07:51 PM
Jdovejdove's Avatar
Put 1oz of seafoam to every quarte of Oil.. drive about 100 miles then change oil.. will get the sludge out. Works magic. Can't stop the sludge from happening in those engine ..
Vision2099
Jan 23, 2017 10:10 PM
Bud Tierney
Nov 2, 2016 10:47 PM
tsprinkle
Jul 17, 2015 01:42 AM
jasenklems
Dec 12, 2009 06:28 AM
lebaron79
Mar 18, 2009 03:38 AM
