2004 300m having problems adding water
Old Mar 1, 2017 | 09:02 PM
supra92's Avatar
Default 2004 300m having problems adding water
I repair my Chrysler 300M I got the heads done, new head gaskets, timing belt water pumps tensioner new injectors
everything is new, engine started immediately and runs great but I can't go far because I'm having a problem adding coolant to the car, I purchase 2 gallons from the dealer and only a 1/4 when in, the small yellow/ white plastic bottle is full but I know the radiator is empty. ( new thermostat )
Help why I can't add any coolant, I also try water.
Old Mar 2, 2017 | 09:55 PM
open the bleeder screw on the front of the intake. Also the best way is to have a funnel on there to keep the water pressure high to force out any air bubbles
Old Mar 3, 2017 | 12:48 PM
If you run it without coolant you will certainly fry the water pump shaft seal.
Old Mar 4, 2017 | 02:50 PM
supra92's Avatar
for some reason I can't add water, I just remove the thermostat and same problem top hose is hot bottom hose cold, I remove the radiator and test it with a water hose, water circulates ok
Old Mar 5, 2017 | 12:23 PM
Hoses have a lining that can become detached and block circulation. Check your hoses. BTW, the bottom hose should be much cooler than the top hose. The coolant comes out of the radiator at the bottom after it has been cooled.
Revots12
Jun 27, 2011 09:48 PM
littlemimus
Oct 17, 2009 02:47 PM
donnyohs
22
Jul 17, 2009 03:19 PM
woodlin321
Oct 8, 2008 09:43 PM
ramfan5.9
Apr 29, 2005 04:51 PM
