2005 chrysler 300
Old May 1, 2008 | 11:30 AM
gmeloche's Avatar
Default 2005 chrysler 300
Hello i am having a problem with my sunroof, it is not sitting flush with the roof of the car it is about 1/8 inch lower and inside the car i can hear wind noise. it doesn't leak but i would like to know if anyone else had this problem and how to fix it.
Old May 3, 2008 | 12:15 AM
Default RE: 2005 chrysler 300
ADJUSTMENT
[ol][*]Move the sunshade rearward to the open position.[*]Separate the mechanism covers (2) from the tabs (1) on the glass panel.
[*]Verify the sunroof glass panel is in the fully closed position.[*]Loosen the forward attaching screws (2) on each side enough to permit the front of the glass to adjust up or down.[*]Adjust the front surface of the sunroof glass panel 0.00 mm to 2 mm (0.00 in. to 0.08 in.) below the top surface of the roof.[*]Tighten the front glass panel attaching screws to 5.5 N·m (49 in. lbs.).[*]Loosen the rear screws (2) on each side enough to make the rear adjustment.[*]Adjust the rear surface of the sunroof glass panel 0.00 mm to 2 mm (0.00 in. to 0.08 in.) above the top surface of the roof.[*]Tighten the rear glass panel attaching screws to 5.5 N·m (49 in. lbs.).[*]Check for proper fit. If not OK, repeat glass panel adjustment.
[*]Position the mechanism covers (2) over the glass tabs (1) between the locating features and seat fully.[*]Verify sunroof operation and alignment[/ol]
Johnny B
Apr 20, 2006 07:40 PM
redriderbob
Dec 9, 2004 03:47 PM
redriderbob
Dec 6, 2004 01:40 PM
