2007 300, ALL 6 cylinders misfiring
Old Jan 23, 2014 | 06:13 PM
nickincam's Avatar
Default 2007 300, ALL 6 cylinders misfiring
I have a Chrysler 300 v6 that is giving me a misfire ofALL 6 cylinders at the same time. This usually happens on the highway or when I am picking up speed. I have brought it to a Chrysler dealershipand my local garage and no one can give me answers. 2 of the coils are new andmy sparkplugs are all new. My check engine light does not always come on and iscurrently not on, so they cannot check for codes. In the past the codes haveread bad coil on #2 and #5, which are the two I have replaced. Those two stillmisfire, along with the rest. I have also had my camshaft sensor changed. Can someone please give me and answer as to what may be causing thisproblem. It is incredibly irritating! Thank you in advance!
Old Mar 12, 2014 | 08:16 AM
Tony Carr's Avatar
I have a 06 300 with the 3.5 and I get a random P0300 and I also get P0301 but I changed the #1 coil, injector, and all the plugs have less than 4000 miles ... the dealer wants me to change the upper plenum before they can ck for the misfire but it's really hard to find one and a new one cost $1800
Old Nov 30, 2014 | 08:57 PM
Duke Orr's Avatar
nickincam, did you discover the problem? My 2008 300 Touring has a similar problem when picking up speed or going up a hill, it jerks quite a bit, wasn't sure at first if it was a transmission issue or ignition issue but I think its missing. I changed the plugs today and no change at all. No codes are shown either and I'm worried about taking it to a dealer for fear of part swapping to try and figure it out.
Duke
Old Dec 9, 2014 | 09:31 PM
svt1314's Avatar
hi im new to the forum i have a 06 Chrysler 300 with a 3.5 i need help turning the vehicle on, the car oil pump went bad and the car turn off on me and it stop the starter from turning the car on, i got a new engine with 60k on it i instal it and now the car still won't turn on, I hear the starter working but the solenoid wont engage i had the starter check and is good please help or if anyone could send me through some direction i will appreciated thank. or please email at svt1314@aol.com thanks.
Old Dec 2, 2023 | 06:42 AM
Jimbob69's Avatar
Misfires check the metal egr pipe at the back of the plenum for any leaks mine had a small leak and it caused random misfires for weeks till I found the problem hope that helps
Tony Carr
Dec 2, 2023 06:38 AM
nut430
Dec 16, 2012 05:21 AM
mrunner13
Cirrus & Breeze
Mar 15, 2008 05:27 PM
jameslee522
Oct 18, 2007 04:24 PM
paul.siwek
16
Jul 29, 2007 10:27 PM
