2010 Chrysler 300c , v6 misfire.
Old Apr 6, 2023 | 04:32 PM
Omarr's Avatar
Default 2010 Chrysler 300c , v6 misfire.
Good afternoon/evening everyone.
I purchased used 2010 Chrysler 300c, AWD V6 3.5 with 170k miles on it. I got misfire on cylinder 5, my mechanic replaced the plug and ignition coil but I still get the same code.
After compression test, it was revealed that cylinder 5 Compression is at 90 (low) should be at 160 psi.
After removing the value cover gasket, he told me that the rocker arm seized !!!!!
Is this something fixable because he told me that a big job and he has to remove the head or I need to put new engine?
Anyone else with the same problem?
Any tip will be much appreciated.
Nardy30
May 18, 2021 11:07 AM
Dadgummit
Dec 21, 2020 05:38 PM
Aly Zaidi
Feb 18, 2020 03:46 AM
bunchakids
Nov 5, 2013 01:30 PM
cjhstang
Sep 18, 2009 10:52 AM
