300 Base model 2006, tranny slipping
Old Dec 1, 2005 | 03:41 PM
TheNeck's Avatar
Default 300 Base model 2006, tranny slipping
I just bought this car Friday, 25th, its an automatic, V6 2.7 liter engine, has around 550 miles on it, with a normal acceleration, it seems like when shifting from 1st to 2nd gear that its slipping, but I could be wrong, Im not an expert when it comes to cars. Any help is appreciated.
Old Dec 1, 2005 | 08:00 PM
seattle's Avatar
Default RE: 300 Base model 2006, tranny slipping
Take the car from a dead stop up a hill, with a load and acclerate hard (no wheel spin) see if it moans at you.
Old Dec 1, 2005 | 09:14 PM
TheNeck's Avatar
Seattle I notice you had a tranny slip problem also, were you able to fix your problem? thanks for the advice, I will try this out when I have a chance. But what do you mean by moans at you exactly? And what if it does or does not moan at me after this test, what does it mean?
Old Dec 1, 2005 | 10:12 PM
seattle's Avatar
What i mean is that when torque is applied to the transmission and drive line from the engine, ie stepping on the gas hard, i get a sound as if the connection between them is not fully connected a vibration that you can actually feel in the body of the car, 2 soft metal parts that are supposed to hook up but don't for a short duration 2-3 seconds. Has to be from a dead stop going up a hill to check for sure. You'll know it it's unmistakable, just make sure you have a full tank of gas and 2-3 other people in the car to make sure.
Old Dec 1, 2005 | 10:18 PM
seattle's Avatar
if you dont have these symptoms it's hard to say whats going on. i will keep you posted on the fix.
Old Dec 2, 2005 | 02:33 AM
TheNeck's Avatar
I will let you know once I have some people in the car with me to try it out. Also this morning leaving my house the tranny seemed fine, but once i got off the freeway for work, from a dead stop it seemed to slip maybe 2 times out of 6-7 stop lights, but when i left work the tranny seemed to be working fine, no problems at all.
tc862011
Sep 23, 2014 04:02 PM
Brendan Tracy
Sep 4, 2014 10:54 AM
tential
Dec 25, 2009 11:24 PM
nagananda_t
Jan 18, 2009 11:09 AM
Cyrus
Mar 15, 2007 02:20 PM
