Blend Door Actuator Gear Location - HVAC Heat/Temp not working passenger side under g
Old Oct 28, 2019 | 11:02 PM
calcala12's Avatar
Exclamation Blend Door Actuator Gear Location - HVAC Heat/Temp not working passenger side under g
Hi Chrysler community during the summer I had posed a forum that my AC was blowing cold on driver side and hot on passenger side Driver Side Blows Cold Air Passenger Side Blows Hot.
After getting multiple suggestions (greatly appreciate everyone help) my issue ended up being that my refrigerant was low. I had changed multiple things like the sunload sensor, humidity sensor, and both actuators on passenger side. Now that we are about to enter November one of that actuators decided to act up, I went under the glove box without hesitation since I had already replace it once.
I ended up removing the assembly that the actuator screws onto, just to make sure I was properly inserting - not knowing there was a Gear under. Looking to see if anyone knows the position of the blend door actuator gear how it needs to be set. Before I replace the actuator
This is for a 2014 Chrysler 300 S left had side of passenger under glove box. Currently its setup (please see pictures)
Thank you
Whydidshebuythis
Sep 27, 2018 05:00 AM
Shenny
Nov 4, 2017 02:58 PM
Badgerswag
Sep 16, 2017 05:45 PM
eignub
Jun 5, 2017 12:06 PM
Jwrbloom
Oct 15, 2013 03:46 PM
