Chrysler 2013 300 Ltd, multiple issues
ERROR in my posted thread. This is for my 2012 Chrysler 300 S/B Chrysler 2012 300 Ltd, multiple issues
Hello All;
I have 2 issues that are ongoing. CEL and P0128 .
P0128 - Thermostat Rationality >Antifreeze level is good car heats up quick here in Minnesota winter.
so I am not thinking I have a Thermostat open/closed issue but am open minded for sure.
Temp gauge is slightly less than 1/2 way on the analog gauge.
Car has not been driven much, maybe 1000 - 3000 miles in the last three years.
Electrical - Currently, I have lost proximity features for door locks and trunk (FOB battery replaced 2 days ago 2/15/2025)
Remote Start Feature - This shuts off in less than 10 seconds, but I am assuming that the CEL being lit is responsible for that but again not sure.
I do not see reason to disconnect battery and then hope the Car Computer relearns everything on reconnect..
Hello All;
Eureka, Success,
After I replaced the thermostat, and driving a few days so the computer could re-learn things, the CEL has turned off, and remote start works again.
Coolant temp is running around 202-204 degrees F. Needle/Analog gauge is in the center of the dial between
Cold and Hot and heated up rather quickly than it did before.
Remote start was enabled from 40-50 feet away and I ran the motor for 10 minutes and never shut off on its own.
Thank You for the help CHRYSLER TECH and ggoose.
Alex Appleton
Jun 17, 2023 03:19 AM
Seholme
Mar 3, 2020 07:12 PM
GuyJeb
Dec 5, 2013 05:53 AM
