Chrysler 2013 300 Ltd, multiple issues
Old Feb 17, 2025 | 12:59 AM
tonypuka4's Avatar
Question Chrysler 2013 300 Ltd, multiple issues
ERROR in my posted thread. This is for my 2012 Chrysler 300 S/B Chrysler 2012 300 Ltd, multiple issues
Hello All;
I have 2 issues that are ongoing. CEL and P0128 .
P0128 - Thermostat Rationality >Antifreeze level is good car heats up quick here in Minnesota winter.
so I am not thinking I have a Thermostat open/closed issue but am open minded for sure.
Temp gauge is slightly less than 1/2 way on the analog gauge.
Car has not been driven much, maybe 1000 - 3000 miles in the last three years.
Electrical - Currently, I have lost proximity features for door locks and trunk (FOB battery replaced 2 days ago 2/15/2025)
Remote Start Feature - This shuts off in less than 10 seconds, but I am assuming that the CEL being lit is responsible for that but again not sure.
I do not see reason to disconnect battery and then hope the Car Computer relearns everything on reconnect..
Old Feb 17, 2025 | 05:33 PM
are you worried about the remote start or the check engine lite issue more?
Old Feb 17, 2025 | 09:47 PM
tonypuka4's Avatar
W O W ....might even help if I put the right year in,,,IT;S A 2012, 73452 miles.
ok, now thay the right year of the car is in, I would say that the CEL is the most important.
Old Feb 18, 2025 | 06:04 PM
you likely have a thermostat issue
Old Feb 19, 2025 | 07:53 AM
ggoose's Avatar
CEL lamp will cancel remote start. Correcting the cause of the p0128 will cancel the CEL and allow the remote start to work as expected.
Old Feb 25, 2025 | 02:26 PM
tonypuka4's Avatar
Thanks for the quick response's
I went and purchased the thermo/housing and will install today if possible.
Update to follow.
Old Mar 3, 2025 | 09:26 PM
tonypuka4's Avatar
Thumbs up
Eureka, Success,
After I replaced the thermostat, and driving a few days so the computer could re-learn things, the CEL has turned off, and remote start works again.
Coolant temp is running around 202-204 degrees F. Needle/Analog gauge is in the center of the dial between
Cold and Hot and heated up rather quickly than it did before.
Remote start was enabled from 40-50 feet away and I ran the motor for 10 minutes and never shut off on its own.
Thank You for the help CHRYSLER TECH and ggoose.
Alex Appleton
Jun 17, 2023 03:19 AM
Seholme
Mar 3, 2020 07:12 PM
polarrich
Dec 17, 2013 04:38 AM
GuyJeb
Dec 5, 2013 05:53 AM
rhino
Jun 10, 2010 04:42 PM
