Chrysler 300 oil indicator
Old Jan 21, 2016 | 09:14 PM
Lilkev's Avatar
Default Chrysler 300 oil indicator
Just have 2.7 liter engine replaced. I still get oil light coming on when at idle after you drive long enough to heat motor up. Went and got oem oil sensor from dealer and still no luck. I hooked a manual gauge up and ran at idle to engine temp and pressure never got below 11 psi. Car does have idle fluctuation also. Any ideas would help......
Old Jan 22, 2016 | 09:29 AM
ChryslerCares's Avatar
What year is your 300?
Old Jan 22, 2016 | 10:26 AM
UltraNutZ's Avatar
I thought these pressures were supposed to be up a little higher than you're seeing?
you need to fix your idle issues for sure because if it's idling below 600, then the oil pump cannot keep up and likely throwing the oil pressure light on because of that.
Old Jan 22, 2016 | 01:04 PM
Lilkev's Avatar
Yeah I can't find anywhere to give the specs but I called engine manufacture and the said 5 psi is the minimum. That still does not help me if the pressure switch kick on at 10 psi. The dang light and chime will drive u crazy.
Old Jan 22, 2016 | 01:05 PM
Lilkev's Avatar
Also I'm like u the idle dropping has to be the issue cause it causes lights to dim also
Old Jan 22, 2016 | 02:45 PM
UltraNutZ's Avatar
if you're around the Houston area, we can coordinate a drive-by to hook up the diag tool and see what's going on. I don't do repairs for anyone else but I'll help you troubleshoot it if local.
Old Jan 22, 2016 | 03:46 PM
Lilkev's Avatar
No I'm in Arkansas about 5 minutes from Memphis TN.
howell_jd
Nov 9, 2010 10:36 PM
howell_jd
Nov 7, 2010 05:07 PM
SEW-4-FUN
Jul 26, 2009 01:23 PM
mcglough
Jun 18, 2008 06:26 PM
rpccc43
Feb 21, 2008 05:09 PM
