Chrysler 300c 2006 electrical problems
Old Dec 22, 2021 | 06:32 AM
baff57's Avatar
Default Chrysler 300c 2006 electrical problems
Hi all
I have a Chrysler 300c 3 litre V6 Diesel 2006 with ABS EPS Traction airbag lights on and no fan on heating and heated rear window etc.
What happened is i went to the car and the battery was flat, put it on fast charge and the battery got extremly hot, i replaced battery to still get the above faults plus diagnostics software report codes for Glow plug control P0670, U0106, P1648
As it seems like a power failure issue i checked all the fuses and all ok, So went to Heater motor fuse (Rear Box) and removed and tested power to the pins, no voltage. There is power to the fuse box and all looks ok . I am guessing that there is issues with power to certain arears of the car.
I see there are 3 self resseting fuses which when removed have continuity but guessing that the fusebox is not supplying power forward to ceretain areas and probably the first point of attack.
So main question why is there power to the fusebox yet the blower fuse has no power? Could it be the Glow plugs are drawing to much current and taking out a ressetable fuse? However the lights on the dashboard are lighting up for glow plugs and going out and the car is starting fine.
Any help please.
1path
Mar 30, 2019 01:57 PM
george3405
May 13, 2016 10:26 PM
s66evl
Nov 19, 2013 06:17 AM
wire.nut
Jun 26, 2011 07:39 PM
mwfarish
May 30, 2008 01:27 PM
