Dash rattle/squeak?
Old Apr 7, 2007 | 01:41 PM
traveler's Avatar
Default Dash rattle/squeak?
Have a 300C w/ only 11k miles on it. I have a squeak coming from the dash or steering Column that I can't seem to locate (holding various areas of the dash). Was wondering if anyone else had experienced that might narrow my search?
Old Apr 7, 2007 | 08:24 PM
Default RE: Dash rattle/squeak?
take it to the dealer
Old Apr 7, 2007 | 10:48 PM
GoofyTimL's Avatar
It may actually be your sunroof, if you have one. I've read of many ppl searching (and having their dealer search) without success for a dash rattle or squeek only to find eventually that it was their sunroof.
Thought it worth mentioning.
Old Apr 8, 2007 | 10:01 AM
traveler's Avatar
Thanks. No sunroof, so at least one down....
Old Jun 3, 2007 | 09:12 PM
mascu's Avatar
my dashboard, arm rest cup holder, and doors squeak...... HATE IT!!!! it's as if it's loose. how do i explain..... for example, the arm rest for the driver. I can apply some pressure to it to move it sideways, and it gives me a squeak. or even with the door close, i pull on the handle or push the handle, it squeaks. So basically, when i'm driving, without touching or doing anything to them, they squeak, probably from vibrations, how do i fix this? better suspension, or..... reinstall the whole thing, or need to put some soft foam between.
please help, really annoying sounds.
Old Jun 3, 2007 | 10:25 PM
u can take off the door panel and install new clips.
Old Jun 10, 2007 | 12:54 AM
mascu's Avatar
i tried taking out the door panel but it wouldn't work....... i took off all the screws that i can see, even the one in the door handle inside. do i pulled it out...... or do i lift it up..... or etc.?
and what did you mean by clips, you mean replace with new screws?
thanks
Old Jun 10, 2007 | 07:54 AM
there are door clips plastic and screws the plastic one will break if removed incorrectly.
rbar123
Mar 25, 2024 06:50 PM
TelecasterMan
Dec 17, 2016 05:40 AM
Skycop385
Jun 22, 2008 07:41 PM
preed4962
Jul 4, 2007 07:44 PM
Hawker95
Mar 4, 2007 02:35 PM
