Light Dimming
Old Jan 10, 2006 | 06:12 PM
johnkaracalidis's Avatar
Default Light Dimming
I have a 2005 300C limited. Often while the car is on, the interior and exterior lights seem to dim up and down. I wouldnt classify this as a flicker, more of a dimming.
From my experience in car electronics (very little) it seems like the altinator is not producing enough power. I dont have any high power after market parts, only a remote starter.
Any help would be appreciated.
Old Feb 26, 2006 | 07:55 AM
LeeSoFL's Avatar
Default RE: Light Dimming
Had a similar situation with my Intrepid ES. Turned out to be the cooling fan has a relay that turns it on and off. When the fan would click on, the most obvious thing would be the headlights (and interior lights if on) would drop down a bit in intensity. I noticed the headlights got a bit dimmer when we were driving a dark back road shortly after buying the car in 1998.
I took it to the dealer and they checked it out, there was nothing wrong with the alternator or anything in the electrical system. It was in fact, the draw of power for the cooling fan.
(PS: I just took delivery on a new 300C and haven't really driven it at night on a dark highway yet, but I would be curious to see if the same thing happens.)
Old Feb 28, 2006 | 01:53 PM
bells's Avatar
lol! My last Intrepid ES did the same thing! The headlights were fine, but all the lighting on the dash and stereo would flicker constantly(it was really distracting at night). I took it in to be looked at twice, but it always come back. Eventually, I discovered that if you roll that little dimmer wheel thingie(lol I don't know the "technical name" but it's right by the headlight switch) out of the lock postion and dim your interrior lights just a tad, they shouldn't flicker anymore. You shouldn't have to play games with your new car, I know...but it's a minor/easy solution. Hope that helps.
Old Mar 5, 2006 | 07:57 AM
LeeSoFL's Avatar
bells,
Those are actually two different problems. The dash lights jump around in intensity because of a quirk in the dimmer switch that controls the display intensity. The problem I had with headlights and interior cabin lights was in fact because of the fan drain. When I would be driving on a dark road, I would see a noticeable dip and recover in the headlight intensity. It wasn't because I was going uphill, or because the A/C was on. It was directly diagnosed as the drain the engine fan causes because the headlights, cabin lights and engine fan are on the same fuse and circuit.
Old Jan 31, 2008 | 09:08 PM
jquinones's Avatar
I hadsimilar problem,I did a tune up and solve the problem!! spark plug was very old (maybe original, all rust)
good luck
sjones
Mar 3, 2009 09:25 AM
sonic gihad
Jan 5, 2009 03:24 PM
pourhouse
Jun 3, 2008 03:08 PM
3.3lxbluevan
Jan 29, 2008 01:18 AM
tgragtop
Oct 12, 2005 02:59 PM
