Location of oil pump and fuel pump on 2005 300
Old Oct 2, 2010 | 05:06 PM
Darth Menace's Avatar
Default Location of oil pump and fuel pump on 2005 300
Hey guys, my dad has a 2005 Chrysler 300 (3.5 L), and when he starts his car it ticks for a little bit. This being said he wants to replace the oil pump in hopes this helps the problem.
Where is the location of the oil pump for this car? Also, where is the location of the fuel pump?
thanks in advance
Old Oct 2, 2010 | 06:33 PM
humm a good waste of money
REMOVAL
Drain the cooling system. (Refer to 7 - COOLING - STANDARD PROCEDURE)
Remove the timing belt. (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT/CHAIN AND SPROCKETS - REMOVAL)
Remove the crankshaft sprocket. (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT/CHAIN AND SPROCKETS - REMOVAL)
Remove the oil pan. (Refer to 9 - ENGINE/LUBRICATION/OIL PAN - REMOVAL).
Remove the oil pickup tube (WINDAGE TRAY AND OIL PICK UP TUBE).
Remove the oil pump fasteners. Remove the oil pump(OIL PUMP AND CRANKSHAFT GEAR) and gasket from engine.
Old Feb 18, 2016 | 10:36 PM
charles92154's Avatar
as for the fuel pump, itself, is on right side under back seat..the fuel filter, fuel press. regulator, is on left side, and also fuel level,gauge...i'm going thru same, well with a 300 like yours and my durango. i'm in the process of checking, relay, and fuze, i dont hear anything from pump when i turn on key. good luck..
Old Feb 19, 2016 | 07:21 AM
UltraNutZ's Avatar
6 year old thread?
Old Feb 19, 2016 | 09:16 PM
better late then never??
johnk
Jan 6, 2021 01:41 PM
jerrypageboone
Mar 25, 2015 05:38 PM
S6Voyager
Mar 25, 2013 11:15 AM
96BTC
Sep 27, 2010 10:29 PM
djslacker
Aug 11, 2009 09:24 PM
