lost instrument gauge readings
Old Oct 8, 2011 | 04:28 AM
orandaberg's Avatar
Default lost instrument gauge readings
Hi
At first I lost the ability to enter the EVIC to change language, so I took off the cable to the battery for a few minutes, then put it back on, the EVIC works now,I have lost the power for the gauges, I have panel lights, but the speed,rev,temp and fuel needles do not move, I removed the instrument cluster to unplug and plug back the 3 connections on the instrument cluster bu that did not work, everything else works in the car,tried looking for a fuse, cannot see one in the list, any ideas
Old Oct 8, 2011 | 05:12 AM
orandaberg's Avatar
The EVIC does show rpms and speed and temp
Old Oct 8, 2011 | 09:03 AM
TNtech's Avatar
In the trunk fuse box check and make sure all of the fuses are seated good. There are also a couple cartridge type diodes that are solid black. Those things can make your car go nuts if they're not in. Many times they get knocked out when people go under the cover messing around.
Old Oct 8, 2011 | 09:50 AM
orandaberg's Avatar
all tight!
jvandyke
Nov 11, 2013 09:29 AM
skid2964
Oct 28, 2012 08:07 PM
DJSix
Oct 3, 2011 03:35 PM
Laimon
Apr 22, 2011 03:35 AM
thetimmer
Jul 2, 2005 10:53 PM
