unusual heat readings.
Old Apr 20, 2011 | 06:00 AM
Laimon's Avatar
Default unusual heat readings.
gents,
today a problem started while engaging AC to my sebring 04 2.7L sedan.
unusual heat, almost at middle of gage, but engine not overheating. ( I have this car for 2 years, heat gage is always at quarter)
6 month ago i replaced head gaskates, water pump, thermostat and water outlet housing..
Fans are working good at both speeds.
note that this happens only when ac is engaged.
any ideas?
Old Apr 21, 2011 | 11:10 AM
United1's Avatar
I would look at coolant flow, leaning towards a partially blocked heater core or radiator. Seems like under a heavy load (AC on) that circulation may not be enough for sufficient cooling, but enough to where it does not overheat. Have you checked (flow, radiator, core) or done a good flush?
Old Apr 22, 2011 | 03:35 AM
Laimon's Avatar
Problem solved by washing radiator, fins where dirty.
later i will drain and clean cooling system, summer has started and must be prepared..
thanks for help
Fress
Nov 19, 2013 03:52 PM
skid2964
Oct 28, 2012 08:07 PM
orandaberg
Oct 8, 2011 09:50 AM
voyager_dan
Sep 12, 2011 05:13 PM
huasi87
Apr 8, 2010 08:53 PM
