Power window strange voltage readings
Old Oct 28, 2012 | 03:28 PM
skid2964's Avatar
Default Power window strange voltage readings
Im trying to fix my left rear power window, bought a new motor but the exisitng motor is ok. When I check the voltage at the wire going to the motor, on either wire I get 10 volts, when I actuate the switch for that circuit (up or down) I get 12 volts.
When I check the other working windows, I get 0 volts then 12 volts. Which is at it should be.
Anyone else ever see this? What is the fix? Wiring upstream?
Old Oct 28, 2012 | 08:07 PM
one 12 one ground is what it should be
mech3
Jan 12, 2016 09:49 PM
estrika
Dec 27, 2013 04:38 PM
orandaberg
Oct 8, 2011 09:50 AM
Laimon
Apr 22, 2011 03:35 AM
1bad300
Apr 18, 2007 03:44 AM
