More Than a fuel pump Issue - Wont stay running
Old Jan 15, 2020 | 05:24 PM
John D'Araneo's Avatar
Default More Than a fuel pump Issue - Wont stay running
My Chrysler 300 with the 3.5 engine stalled out and wont start up right since. It starts for a second and runs for a second and starves for fuel. I replaced the fuel pump assembly and it still wont start or stay running. The pump is working. We tested the voltage. When we first turn the key we get 12+Volts but within 3 sends it drops to zero.It will start 1 out of 8 times trying but only runs for a few seconds and sounds like it is starving for fuel. Any ideas???
Old Jan 15, 2020 | 07:40 PM
check for fuel pressure at the rail that will confirm you are or are not having fuel at the engine.
Old Jan 16, 2020 | 08:16 AM
ChryslerCares's Avatar
Hi John,
I'm sorry to hear of the trouble you are experiencing. If you are not able to determine a solution based on suggestions provided by fellow forum members, we kindly recommend following up with your local Chrysler dealer for further assistance. Our team is just a private message away if you do work with your dealer and additional support is needed for that process.
Mark
ChryslerCares
Brent Samuels
13
Mar 3, 2020 03:15 PM
maintenance
Apr 30, 2015 05:15 PM
crazymanrols
Mar 29, 2014 12:55 PM
Mama2Saigai
Jul 24, 2013 01:46 PM
darlon
Apr 19, 2010 06:19 PM
