Mysterious RPM drop
Old Feb 4, 2021 | 07:15 AM
Joseph Brando's Avatar
Exclamation Mysterious RPM drop
Hello,
2013 300 V6 engine with over 100.000 miles
After replacing the famous rocker arms and lifters on both banks, the RPM exhibits the following :
1. Idle after warm-up 630-640, prior to repair was closer to 700.
2. Idle drops to 500 when stopping at a traffic light, etc it will go up to 630-640 if I tab the gas pedal and/or turn the steering wheel, and It stays there.
3. it will NOT drop when A/C is ON
4. Hood opened, when revving while idling I hear wooshing sounds (like suction sound)
how much of that suction/wooshing is normal with TB wide open? or suspect a vacuum leak?
I am waiting on a new scan tool, will look at fuel trims, MAP, O2, plus other sensors, and post results.
No check engine code starts and runs good, no problems otherwise.
Old Mar 7, 2021 | 03:21 PM
likely a vac leak spray brake cleaner in the engine area and see if the rpm boosts up if so then you have you leak area.
Old Mar 9, 2021 | 08:13 AM
Thank you, sir, you are a gentleman.
pestilance
Jan 24, 2012 04:01 PM
sonyatracie
Mar 10, 2011 02:12 PM
BEAST2011
Jan 15, 2011 10:36 PM
sebringted48
Jun 7, 2009 04:27 PM
dckoone
May 29, 2008 06:02 PM
