Oer heating 2011 300 limited 3.6 flex fuel
Old Jun 25, 2022 | 11:05 PM
Silverbox's Avatar
Default Oer heating 2011 300 limited 3.6 flex fuel
Please help ok . So first thank you for adding me to group i own 2011 limited 300. Recently it developed a issue with running hot . So things i hav e done .new radiator, water pump, thermostat an housing, oil cooler ,,coolant sensor, plugs,blet,. Am i missing something . And caps . I burp it on ramps run till warm then cap it .i squeeze the lines get out bubbles. .after i burp it it comes up to temp right around 204then drops 196 . I drive it gets to 208 then drops 196. About half hour of driveing temp spikes 220,230,240,an so on i shut it down around 250 befoe red light comes on . What am i missing .i bore scopped cylinders didnt see anything out of normal. No smoke no coolant in oil an vise versa .i know the actuator is bad could that be the cause ????please any info would be greatly appreciated
Old Jun 27, 2022 | 08:20 AM
tarhealcracker's Avatar
Holy Cow. Seems like you have done all the right things. Given all the things you have done one hardly knows where to start. If I had to guess on what you are missing I would go with water pump and/or thermostat.
Old Jun 28, 2022 | 01:49 AM
Silverbox's Avatar
Thanks i have changed all the above . I pressure tested the coolant system an it has a very light drop . So i am not so sure what it is . It drops 1/4 pound in 2 hours .cant hear or see any visible leaks .i covered e every square in of motor an lines with some really bubbly solubtion can fi n d abythugsmm
Old Jun 28, 2022 | 08:29 AM
ggoose's Avatar
Has the radiator cap itself been replaced? May be obvious but must ask.
Old Aug 3, 2022 | 01:50 AM
Silverbox's Avatar
Default Update
so gey this . After all i finally fixed issue coolant recovery tank. That was the issues all alpng
Old Aug 3, 2022 | 07:01 AM
Good on you for getting back to us with the fix. So few do !
Old Aug 3, 2022 | 10:32 AM
Silverbox's Avatar
Default No problem hopefully if someone is having the same issues this will be of some help
no problem .far to many people think these are just to post pics on .but some of us look towards them for advice sometime taken sometimes giving..my new issues i stated running flex fuel an now its throwing lean codes . Never did it before
carguy2077
9
Aug 25, 2022 04:29 AM
Cardovan
Jul 1, 2022 01:24 PM
2lites
Sep 23, 2021 05:53 AM
KBC
May 18, 2017 10:00 PM
Pologuy
May 31, 2015 02:02 AM
