Spiderlite LED Tail Bulb Lights 4 Chrysler 300
Old May 8, 2005 | 03:15 PM
LGT Automotive.com's Avatar
Default Spiderlite LED Tail Bulb Lights 4 Chrysler 300
Introducing a new and innovative automotive exterior lighting accessory! A dazzling replacement
to standard automotive tail light, brake, and turn signal light bulbs! Giving your stock tail lights a
distinctive look and the latest ultimate in LED technology. This inventive new product replaces
standard rear brake and taillight bulbs with a 3 or 5-arm LED light that expands inside your stock
taillight assembly to give it an updated appearance.
Features & Benefits from LGT Automotive
High Intensity Leds
30 Leds on Spiderlite 5 arm large model
18 Leds on Spiderlite 3 arm large model
Forms a Distinctive Pattern
No Modifications to Your Vehicle Required
Connects to Standard Wire Harness Sockets
Collapses For Installation Through a Standard Mounting Hole
Automatically Expands After Passing Through The Mounting Hole
Available in 2 models [ 3 arm & 5 arm ]
Each model is available in 3 sizes [ large - medium - small ]
Back Leds will give you even more output light as it reflects off the
inner tail light housing
Stylish Retail Packaging consisting of a protective plastic clamshell
with a colorful graphics card insert
Product Specs:
View:
Spiderlite Models & Parts Schematic Important [ Please Check Before Purchasing ]
Spiderlite 3 Arm Model Installed
Spiderlite 5 Arm Model Installed
Spiderlite 2 Pin Electronic LED Flasher Model
Spiderlite 3 Pin Electronic LED Flasher Model
If you are replacing a light bulb that uses the flasher [ ie: turn signal ] you will need to replace
the flasher with one of the Electronic LED flashers above. This will prevent the double flash rate.
The flasher comes in 2 pin and 3 pin versions. Check which flasher is currently in your vehicle and
select the model with the same number of pins. PLEASE NOTE THAT ONLY ONE FLASHER IS REQUIRED.
Installation Instruction & FAQs
Click Here For More Info & Installed Photos:
Made in Canada by Spiderlite Inc. A 2004 Sema Show Award Winner For Best New Exterior Accessory Product.
*Please ensure that this product will properly install in your tail lights before purchasing. View the "Do Not Fit Chart"
Edited: Images were broken for some odd reason.
carid
Feb 10, 2015 08:55 AM
Comrade
Sep 25, 2011 07:20 AM
crandell87
Jan 12, 2010 10:43 AM
gsxsebring
Feb 8, 2009 12:59 AM
Johnbush1
Feb 22, 2008 04:00 AM
