07 Aspen DTC P0196
Old Jun 23, 2013 | 06:20 PM
Tony Moore's Avatar
Default 07 Aspen DTC P0196
Check engine light came on this morning when i started the vehicle. Ran it through my OBD II reader and got code P0196. Ive looked it up and got the Engine Oil Temperature Sensor Range/Performance. All the DTC lists ive looked at shown this code in red? Not sure what that means. Also dont know what to check, the sensor? Wiring? Any help is much appreciated. A little frustrated at this point...
Old Jun 25, 2013 | 08:38 PM
15951a\'s Avatar
It's either the sensor, a short, or the PCM in more unusual cases. The sensor is a $30 part...that's where I would start if you don't want to pay someone for diagnostics.
Old Jun 27, 2013 | 10:12 AM
mrfixit's Avatar
P0196 CHRYSLER Description
The engine oil temperature sensor is used to detect the engine oil temperature. The sensor modifies a voltage signal from the Engine Control Module (ECM). The modified signal returns to the ECM as the engine oil temperature input. The sensor uses a thermistor which is sensitive to the change in temperature. The electrical resistance of the thermistor decreases as temperature increases.( in short change the oil switch )
yosemiteindy
May 30, 2019 02:24 AM
brushhog
Nov 30, 2011 11:35 AM
jeffgzfs
Sep 21, 2011 10:00 AM
unikgtz
Sep 15, 2009 08:02 AM
yosemiteindy
May 28, 2007 09:12 PM
