2007 bluetooth
Old Aug 13, 2010 | 10:24 AM
conversion02's Avatar
Default 2007 bluetooth
I read a review on CNET and they said bluetooth was an option on the 2007 models (which I didn't think it was). Is adding the bluetooth as easy as replacing the rearview mirror? I can't imagine anything would change in the nav unit for a simple $360 option. The wiring to the rearview mirror should be generic plug and play. It seems as though all I would need is the mirror instead of my generic autodim mirror...right?
Old Aug 16, 2010 | 12:32 PM
jimhild's Avatar
Bluetooth was available on the 2007 Aspen. I don't think it is simple to add if not included at the factory.
Old Aug 23, 2010 | 09:00 PM
luv2byte's Avatar
You can have Chrylser order the U-Connect module & install it. Works GREAT! No you don't change out the mirror, they simply put the mic in a place of your choice, reprogram your the system & tada, 2hr later hands free blue tooth. I forgot how much I paid for mine but it was around $300 installed. I've also had the MP3 cable added to my system, it also works well, was about $150 installed.
Old Aug 30, 2010 | 07:27 AM
tipopilota's Avatar
Where did u get the mp3 cable installed at?? Did u have to give anything up like the sattelite or dvd for it to work.
Old Oct 24, 2020 | 09:42 AM
Stephanie Potter McKee's Avatar
Default Uconnect reset
My Uconnect no longer works. Every time I start the engine it asks me to follow the voice commands to reset. I have done this dozens of times and nothing works. The feature will not link to my phone's bluetooth either. Is there a way for me to do a factory reset??
justawop
May 29, 2009 11:24 PM
Becky
Aug 27, 2008 09:48 AM
billc4s
Jun 29, 2008 09:48 AM
luv2byte
Mar 13, 2008 07:56 PM
Tattoo You
Mar 7, 2008 09:11 AM
