2007 - Weird Idle / Random Dies Driving
Old Oct 25, 2020 | 08:41 PM
NxtGenCowboy's Avatar
Unhappy 2007 - Weird Idle / Random Dies Driving
Hi!
I was hoping to get some assistance with our 2007 Aspen 4.7 Flex(I do not run Flex gas). It has about 77k miles on it, mostly used in FL. Now it is located in IL and we are starting to have a few weird issues. It started to idle funny, right at 600 RPM then jump to 1200 then fall to like 400. Sometimes it'll turn off but not usually. I already swapped out the Idle Control valve(that didn't fix the issue). I was coming home from work the other day, super short 5 mile drive. I was coming down a back road and the Aspen just died. I turned it off, let it sit for a few minutes, started back up. The engine light is on now, throwing code P2074, Manifold Absolute Pressure/Mass Air Flow -- Throttle Position Correlation at Higher Load. I did install a new filter also checked to make sure nothing blocking the air path. I am confused at my next move, do I swap out the TPS(Throttle Position Sensor) or MAP(Manifold Pressure Sensor)? Or am I in the wrong ball park and should be doing something else..
Old Nov 1, 2020 | 07:05 PM
themps's Avatar
Originally Posted by NxtGenCowboy
Hi!
Probably needs a new TPS.
MOPAR5017479AA
or STANDARD MOTOR PRODUCTSTH190
But you might as well do the MAP as well. MOPAR 56041018AD
Last edited by themps; Nov 1, 2020 at 07:07 PM. Reason: But you might as well do the MAP as well.
Old Nov 2, 2020 | 12:24 PM
Thanks. I'll order them and swap them out..
Old Dec 24, 2020 | 03:16 PM
So my battery was leaking a little bit and I swapped it out.. That seems to have fixed it, which is odd.. Now to figure out why it takes 20 minutes to get to temperature
Old Dec 25, 2020 | 10:36 AM
ggoose's Avatar
Not odd at all, a weak or failing battery will cause a low voltage condition. It is well known that Chryslers do not tolerate low voltage which causes all sorts of random weirdness.
Old Apr 21, 2021 | 04:31 PM
Well the issue is back.... I have NOT replaced the TPS yet but I did throw the code today, P0068 -- Which apparently is MAP/MAF Throttle Position Correlation. Do I replace the TPS first or do I something different?
The above would be here Saturday Or am I better off going throgh RockAuto(wont be here for another week)?
dyson77
Apr 23, 2015 10:47 AM
richjones19772000
Feb 5, 2014 04:29 AM
godsall84
18
Aug 13, 2013 06:34 AM
Yates
Mar 10, 2012 09:44 AM
gbwiii
Jan 6, 2009 03:48 AM
