2008 electrical issue..please help
Old Oct 13, 2010 | 08:28 PM
brtims's Avatar
Angry 2008 electrical issue..please help
Hi.
Here is the deal. while driving all of a sudden the dashboard lights up with all warning lights lit, the dashboard is frozen completely. No mph,rpm, which gear I am in ..etc frozen. The AC doesn't work and the engine fan sounds like full blast. If I turn the car off for a few hours it goes away with the exception of the check engine light. A few more hours later then that goes off. Dealer did not find anything (because it recovered on its own). this has occurred twice within 30 days of each other. I hope someone has had this issue and it has been resolved.
Brian
Old Oct 18, 2010 | 09:01 AM
Aspen188's Avatar
Default electrical
Check my post(Aspen188) two posts below yours. If your getting water coming in your truck like mine then pull the plastic panel off down by your parking brake. Disconnect the fuse plug harness from fuse block and it should be dripping with water. If so, blow dry it dry then take some electrical grease and pack it in there and plug it back together. This will push out any remaining water and hold continuity between the connections. Then, sell it!!!!
mpls_apple
Mar 22, 2013 09:09 AM
jfryling
Oct 8, 2011 08:59 AM
catagory5
Sep 21, 2010 02:16 AM
ARegularGuy
Apr 30, 2009 05:57 PM
tehkoch
Sep 17, 2008 11:23 AM
