Aspen block heater cord temp sensor?
Old Dec 26, 2011 | 09:55 AM
Milbers's Avatar
Default Aspen block heater cord temp sensor?
Hi,
Does anyone know if the block heater cord on the 2007 Aspen has a temperature sensor on it? I live in northern Canada and really need it to work. I've owned GM up until now and they have a sensor on the end of the cord that keeps the heater from working until 0°F (-18°C).
The Aspen block heater cord has a small rectangular rubber chunk on about 5" from where it plugs into the block that may contain a sensor.
Pulled it off and plugged it in and it shows 120 volts (at room temp)so guessing sensor isn't present.
Can't hear a hissing noise so not sure if it's even working.
Any help would be great.
Thanks.
Old Dec 27, 2011 | 08:00 AM
Milbers's Avatar
Figured it out myself and for the record there is no temperature sensor on these units. I plugged it in and crawled under the vehicle with the engine cold. I could feel the heat coming off the block heater housing no problem.
gr00vyd0
14
Aug 29, 2020 01:53 AM
Lawrence Stauffer
Dec 27, 2014 01:52 PM
H69
Dec 4, 2009 05:12 AM
Sierrasan
Jan 29, 2009 09:04 PM
lightguypro
Dec 20, 2008 04:32 PM
