battery removal
Old Feb 5, 2010 | 10:09 PM
hawkion's Avatar
Question battery removal
Greetings experts,
How do I remove the battery from my 2007 Aspen?
It doesn't appear to be locked in place, but it won't budge at all! There is no bracket going across the top like I've seen on other models. How does one take the thing out?
Thanks for your time.
Old Feb 6, 2010 | 10:27 AM
15951a\'s Avatar
Turn the ignition switch to the Off position. Be certain that all electrical accessories are turned off.
Loosen the battery negative cable terminal clamp pinch-bolt hex nut.
Disconnect the battery negative cable terminal clamp from the battery negative terminal post. If necessary, use a battery terminal puller (2) to remove the terminal clamp from the battery post.
Loosen the battery positive cable terminal clamp pinch-bolt hex nut.
Disconnect the battery positive cable terminal clamp from the battery positive terminal post. If necessary, use a battery terminal puller (2) to remove the terminal clamp from the battery post.
Remove the battery cables from the battery.
Remove the battery thermal guard (1).
Remove the battery hold down bolt (1) and battery hold down (2) from the battery.
WARNING: Wear a suitable pair of rubber gloves (not the household type) when removing a battery by hand. Safety glasses should also be worn. If the battery is cracked or leaking, the electrolyte can burn the skin and eyes.
Remove the battery from the battery tray.
Old Feb 7, 2010 | 07:50 PM
hawkion's Avatar
Thumbs up exactly right
Wow, you really know your stuff! That's exactly right. I was able to locate the bolt by holding the insulation padding against the side of the battery a bit. It's a very tight fit due to the air ducting right next to it.
Thanks for your help!
tbird2340
Aug 9, 2011 09:57 PM
nvspacifica
Apr 15, 2007 07:22 PM
Johnny B
Apr 20, 2006 07:40 PM
Dusto
Oct 3, 2005 06:17 PM
ezgoinn
Jul 29, 2005 11:44 PM
