Chrysler aspen hid... Fog lights... 2007 aspen
Hey how is everyone doing on here. Im new to this so im still trying to get the hang of it.
I have a 2007 chrysler aspen, i just did a hid upgrade on my headlights. It was easy and fast to install. Everything came out perfect. I installed 6000k lo beam bulbs. Which are awsome
i have another kit, h10 for my fog lights. The problem is i dont know how to remove the old one.
Do i have to remove the whole bumper?
Or just the light?
Anyone know how to do it?
Thanks!
Or just the light?
Thanks!
BULB
CAUTION: Do not contaminate the bulb glass by touching it with your fingers or by allowing it to contact other oily surfaces. Shortened bulb life will result.
Disconnect and isolate the battery negative cable.
- Remove the fasteners that secure the front of the front fender wheel house liner to the bottom of the front fascia.
- Pull the front of the front fender liner rearward far enough to access the back of the front fascia.
- Reach under and behind the front fascia to access the front fog lamp housing on the back of the front fascia.
- Disconnect the wire harness connector (1) from the fog lamp bulb connector receptacle.
- Firmly grasp the bulb on the back of the housing and rotate it counterclockwise (2) about 30 degrees to unlock it.
carid
Jul 21, 2014 09:15 AM
