Code P0440
Old Feb 16, 2014 | 08:27 PM
fmendez65's Avatar
Default Code P0440
Ok I got this code P0440 from autozone today on my 2007 Aspen 4wd 5.7 Liters . I already changed the gas cap and the check engine light came back on. I was doing some research online and I found some information regarding the ESIM ( Evaporative System Integrity Monitor). I wanted to know where this switch is located and if i can just replace this switch without changing the whole canister. Here is the switch I found on ebay.
New Chrysler Dodge Mopar Plymouth Esim Sensor OBDII P0440 Evap Emissions Switch | eBay
Let me know what you guys think. I just reached 102,000 miles and I just paid it off this week so go figure. I had the 100,000 mile warrenty and Its like they have a switch at the dealer that they use to make stuff start going bad. HAHA Well Thanks in advance.
Old Feb 16, 2014 | 10:02 PM
yeah thats all u need that is the whole esim give it a shot
Old Feb 17, 2014 | 08:03 AM
fmendez65's Avatar
Cool well thanks for the reply. Do you know if the dealer sells this part by itself or do they try to sell you the whole canister?
Old Feb 17, 2014 | 08:07 AM
fmendez65's Avatar
Sorry I forgot to ask where is this part located. I think I saw it on the drivers side in front of the gas tank. It is a black canister with lines attach to it. Right? Once again thanks for your help.
Old Feb 17, 2014 | 09:38 AM
yeah dealer should sale it by itself
Old Feb 27, 2014 | 09:42 AM
fmendez65's Avatar
ok so I changed the ECIM on my truck and the code P0440 is still coming after the computer was cleared by my friend with his scanner. Any ideas?
Old Feb 27, 2014 | 09:54 AM
fmendez65's Avatar
Could it be my purge valve solenoid? Where is that located?
Old Feb 28, 2014 | 12:15 AM
under the hood with some vac lines coming out of it. One of the lines is also a possible issue cracked rubber.
Old Mar 11, 2014 | 02:35 PM
fmendez65's Avatar
I found that solenoid but how do you remove those clips? They are white. I was trying to smoke my system but I also couldn't find a port. Any ideas?
sbuyce1
Apr 9, 2015 10:29 AM
vanislepac
Sep 21, 2014 10:28 AM
2003sebring
Mar 23, 2011 07:55 PM
ManuteSwol
Sep 30, 2009 12:46 PM
donnyohs
Dec 3, 2007 04:19 PM
