Help with front end noise on 07 Aspen
Old Nov 21, 2013 | 03:43 PM
Yates's Avatar
Default Help with front end noise on 07 Aspen
Hello everyone don't really post much here but I have a question. My wife has an 07 Chrysler Aspen and when you go over bumps at slow speeds you here some kind of noise. Not so much a clunk but some kind of noise when the truck suspension is going down. It does not happen when the wheel is turned only going straight. I changed the sway bar bushings and all shocks. What else could it be. I know of one other thing that I probably will end up changing but I want to see if anyone else has any ideas. Again it's not a clunk like a tie rod but sounds like a scraping sound. And yes I did check to make sure nothing is hanging off the bottom of the truck. Any insight would be greatly appreciated. Thanks.
Old Dec 5, 2013 | 09:47 PM
Sine Metu's Avatar
When you say that you changed the sway bar bushings do you mean the end link bushings that attach the bar to the control arm or the bushings that attach the bar to the frame or both. Usually the trouble is the bushings that attach the bar to the frame.
Old Dec 10, 2013 | 04:46 PM
KingZeke's Avatar
I too am curious on this as my 08 has a similar noise when at slow speeds. Not sure where to look first. I know my shocks are going and not sure if it just needs to be lubed up under there or what.
Old Dec 13, 2013 | 07:19 AM
bjatwood's Avatar
My 07 does this exact same thing. Much more so when it is cold outside, and I have new shocks too. I am taking it in for service on a tranny line drip, and HVAC display lighting issue too and a general look over before my warranty is over in 6,500 miles...
rtp
May 25, 2024 07:40 PM
mashpar
Jan 27, 2022 10:08 AM
burkj
Aug 20, 2014 03:26 PM
gaz440
Feb 21, 2007 02:37 PM
matune1
Jul 28, 2005 05:43 AM
