Idling Problems
Old Feb 8, 2008 | 05:21 PM
sumcerious's Avatar
Default Idling Problems
I have 3300 miles on my 2007 Aspen.When I reached approx. 900 miles I began noticingrough vibrations when braking at red lights.It started out happeninginfrequently, but now it's all the time. I took it to the shop several times to have the idling system checked and they told me that it was designed like this. Has anyoneelse experienced this problem?
Old Feb 8, 2008 | 05:41 PM
valleybill55@aol.com's Avatar
Default RE: Idling Problems
i have about the same amount of miles on my 2008 with the hemi, no problems yet.
Old Feb 8, 2008 | 05:45 PM
jimhild's Avatar
We have just over 10,000 miles on ours and no issues of any kind. Try another dealer and try another brand of gasoline.
Old Feb 8, 2008 | 06:05 PM
sumcerious's Avatar
I tried changing the gas (started using 93)and still no change. I was told by the service tech that "all the Aspens/Durangos were designed to idle at 500 rpm which makes a rough ride while waiting at lights." I justwanted to get some feedback from other owners; as I can see "everybody" is not having this problem.
Old Feb 8, 2008 | 06:31 PM
jimhild's Avatar
Our Aspen is gone this weekend, but when it gets home I will check the idle speed at a traffic light, I think it is about 600-625 rpm. Will let you know, but it is very smooth at idle.
Old Feb 9, 2008 | 09:26 AM
r.p.m. 600 maybe a little over 600 the idle is very smooth.
Old Feb 9, 2008 | 12:06 PM
luv2byte's Avatar
When sitting idol you cannot even tell my Aspen is even on, I have an 2007 4.7.
Old Feb 12, 2008 | 02:10 PM
jimhild's Avatar
Just got the Aspen back to check RPM. Idles between 600-625 with A/C on, transmission in drive and stopped at traffic light.
Very smooth idle, no issues at all.
Old Feb 13, 2008 | 02:21 PM
sumcerious's Avatar
What is your rpm at traffic lights without the AC on? I was informed that the rpm would increase if theACis on. Riding around with the AC on iswhat they suggested that I do if I wanted to stop the car from shaking. So if you stop at a light with the AC on you should notexperience a problem.However,if you turn the AC off and you stop at a light the rpm would decrease to500rpm and you would experience a rough idle.
My rpm at traffic stops without the AC on is 500 rpm.
Old Feb 13, 2008 | 03:17 PM
jimhild's Avatar
I will be out in about an hour and will try with A/C turned off.
