question about Transfer Case Fluid Change
Old Jun 12, 2012 | 09:08 AM
aggiejet's Avatar
Default question about Transfer Case Fluid Change
Howdy,
OM says to change the transfer case fluid at 150,000. I can't find anywhere what the capacity is or any guidance about how much to put back. Do you just add fluid till it is full and starts running back out of the "add" hole?
I know to "put back same amount as came out" theory, but looking at the area, I think I'm gonna lose some on the frame etc.
Thanks,
Mark
Old Jun 12, 2012 | 11:29 AM
what u do is add it in until u can stick your finger in the hole and bend it down once its on the tip of your finger its full.
Old Jun 30, 2012 | 03:25 PM
15951a\'s Avatar
Is that seriously how you guys check the fluid level?
Old Jun 30, 2012 | 11:12 PM
TAKE NOTE OF NUMBER 9 YES THIS IS STANDARD PROCEDURE IF U HAVE A BETTER WAY OF LOOKING INSIDE A REAR DIFF AND SEEING HOW MUCH FLUID IS IN THERE BY ALL MEANS LET ME KNOW.
LUBRICANT CHANGE
1.Raise and support the vehicle.
2.Remove the lubricant fill hole plug from the differential housing cover.
3.Remove the differential housing cover and drain the lubricant from the housing.
4.Clean the housing cavity with a flushing oil, light engine oil, or lint free cloth. Do not use water, steam, kerosene, or gasoline for cleaning.
5.Remove the original sealant from the housing and cover surfaces.
6.Apply a bead of Mopar® Silicone Rubber Sealant, or equivalent, to the housing cover Apply Sealant
Install the housing cover within 5 minutes after applying the sealant.
7.Install the cover and any identification tag. Tighten the cover bolts to 41 N·m (30 ft. lbs.) torque.
8.For Trac - lok(TM) and Vari-lok(TM) differentials, a quantity of Mopar® Trac - lok(TM) lubricant (friction modifier), or equivalent, must be added after repair service or a lubricant change. Refer to the Lubricant Specifications section of this group for the quantity necessary.
9.Fill differential with Mopar® Hypoid Gear Lubricant, or equivalent, to bottom of the fill plug hole. Refer to the Lubricant Specifications section of this group for the quantity necessary
CAUTION: Overfilling the differential can result in lubricant foaming and overheating.
10.Install the fill hole plug and lower the vehicle.
11.Trac - lok(TM) and Vari-lok(TM) differential equipped vehicles should be road tested by making 10 to 12 slow figure-eight turns. This maneuver will pump the lubricant through the clutch discs to eliminate a possible chatter noise complaint.
Old Jul 1, 2012 | 05:54 PM
valleybill55@aol.com's Avatar
thats been the norm.for ever.
Old Nov 2, 2012 | 12:42 PM
bjatwood's Avatar
You can pump it in from the bottom drain plug hole until it comes out of the top fill hole too. If you want....
yllbwbnna
Jan 27, 2014 09:08 PM
chadk66
Aug 28, 2011 08:26 AM
lowdown73
Aug 29, 2010 11:53 AM
alan509
Aug 2, 2010 05:10 PM
rockandrollaf
Sep 27, 2008 05:48 AM
