Rebuilt engine will not start
Old Jun 28, 2014 | 07:03 PM
drake1's Avatar
Default Rebuilt engine will not start
I have a 2007 Chrysler Aspen with a 5.7L. I just purchased a rebuilt motor because the last one ran hot. I have placed the new motor and everything is hooked up but will not crank. It will turn over all day long and want to crank but will not. I am all out of ideas on what could be preventing this. Any help is appreciated.
Old Jun 28, 2014 | 09:41 PM
same year engine as u took out? Professional rebuilt? what about the cam and crank sensors are the working?
Old Jun 29, 2014 | 06:22 AM
drake1's Avatar
It is the same year and it came from Spartan engines. The only codes that are popping up are the IAT Sensor 1 code when we plugged up the machine we borrowed from Advance Auto.
Old Jun 29, 2014 | 01:18 PM
15951a\'s Avatar
If you're smart enough to install a rebuilt engine, you already checked the obvious stuff we're going to mention -- new plugs, check fuel pressure, make sure injectors are good, etc.
Old Jun 29, 2014 | 03:38 PM
drake1's Avatar
Got the car started. Was ceank sensor but now its running hot. Thermostat is working. Any ideas?
Old Jun 29, 2014 | 08:27 PM
fan working?
Old Jun 30, 2014 | 01:33 PM
15951a\'s Avatar
Fan, thermostat, radiator, and water pump. If it's any of these things and you replaced the engine only because it ran hot...
avondj40
May 17, 2015 11:38 AM
hink-aspen-07
Oct 24, 2012 10:17 PM
jeremiahm
Mar 6, 2012 05:23 PM
Attitude0917
Jun 15, 2008 11:15 AM
E85Fan
Mar 20, 2006 02:45 PM
