Replacement key?
Old Apr 18, 2012 | 05:16 PM
skid2964's Avatar
Default Replacement key?
I have a 2007 Aspen and want to buy a third key. if I have two keys isnt it easy to program a third? what is the proceedure to do this and where can I buy a blank key?
Old Apr 18, 2012 | 09:38 PM
In your owners manual it will tell u how to do this
Old Apr 19, 2012 | 02:23 PM
ChryslerCares's Avatar
If your vehicle is equipped with the Keyless Entry option, you may purchase a key fob or fobs from your dealer. Your dealer can then program them for you.
You can also program new keys to the system if you have two valid sentry keys by performing the following procedure:
1. Cut the additional Sentry Key Transponder blank(s) to match the ignition switch lock cylinder key code.
2. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and
remove the first key.
3. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
4. Insert a blank Sentry Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off. The new Sentry Key has been programmed.
The Keyless Entry Transmitter will also be programmed during this procedure.
Repeat this procedure to program up to a total of 8 keys.
If you do not have a programmed sentry key, contact your dealer for details.
NOTE: If a programmed key has been lost, see your dealer to have all remaining keys erased from the systems memory. The remaining keys must then reprogrammed. This will prevent the lost key from starting your vehicle. All vehicle keys must be taken to the dealer at the time of service to be reprogrammed.
Old Apr 19, 2012 | 02:53 PM
15951a\'s Avatar
Blanks w/fobs are as cheap as $10-20 on ebay.
jpenrose
Jul 21, 2014 03:14 PM
darkcild101
Jul 10, 2014 02:10 PM
c0ast3r_fan
Apr 1, 2014 03:26 PM
grahamp
Jan 26, 2010 01:50 AM
JXI101
Dec 4, 2005 12:39 PM
