Replacing Headlight & foglight lamps
Old Jan 24, 2009 | 05:52 PM
BIGMAN55's Avatar
Default Replacing Headlight & foglight lamps
I just completed installing new lamps for headlights and fog lights on my 2007 Aspen (upgraded to silverstar) I followed the routine the owner' manual suggested up to the part where you have to remove the light fixture instead I folded back the inside fender panel as the manual suggested for the fog lights but I was also able to access the headlights without removing the fixture of course I have big arms and I was working by touch but I still was able to replace bulbs relatively quick those of you with smaller arms it should be a breeze but remember when installing new bulbs not to touch the bulbs with oily hands or allow it to touch anything oily taking the bulb out is not as critical because you're repalcing them anyways but once I removed old bulb a quick wipe around the opened area and I used a plastic bag (clean of course) to cover the bulb section to reinstall works fine.
Old Jan 24, 2009 | 06:50 PM
SARG's Avatar
Default RE: Replacing Headlight & foglight lamps
Do you believe they are any brighter ?
Old Feb 13, 2009 | 08:00 PM
justawop's Avatar
Just changed mine, found it way easier to use a deep socket, long extension that way you don't have to reach inside at all. Just be careful not to drop the nut when you pull the socket through the wheel well.
salvonrico@verizon.net
Apr 24, 2015 12:22 AM
2pt2
Oct 29, 2013 08:11 AM
nealg58
Aug 24, 2011 03:53 PM
jeff618
Aug 15, 2011 11:47 AM
slimonize
Oct 26, 2007 11:20 PM
