"Tinny Clunk " from rear end
Old May 30, 2012 | 09:55 PM
albundy's Avatar
Question "Tinny Clunk " from rear end
HI: I have an'07 Aspen with 50K miles on it and when I go over a small bump, at very low speeds (10mi/hr), I get a faint tin type "bong" sound(Like hitting a steel drum with a rubber mallet). from the rear end. It doesn't happen if I go over a bump fast(> 20mi/hr). Seems to only happen at a crawrl speed. This happens going straight and when turning. I took it to the dealer and they replaced the rear shocks but this did not cure the problem. Any thoughts ?
Old Jun 9, 2012 | 08:51 PM
15951a\'s Avatar
Could be a lot of things. Check to make sure it's not something inside the truck first -- make sure the jack, etc. to change the spare is secure, and that there's nothing metal banging around in the compartment behind the 3rd row. It would also be worth crawling underneath and pushing/pulling on shields, the muffler, etc. Something could simply be loose.
Old Aug 21, 2012 | 07:45 PM
cmwmmw's Avatar
i have the exact same noise in my wifes aspen, i still have not found the source but it defiantly is coming from the rear suspension, i can hear the noise if i rock the car side to side but not if i jump up and down on the hitch, any help would be greatly appreciated
Old Sep 3, 2012 | 09:03 PM
Moparmeister's Avatar
My first instinct would have been the shocks, since the oem shocks are such crap, but since they already put new ones in, that rules that out.
By the way you describe the noise, I wonder if your spare isn't tightly drawn up against the bottom of the truck, or needs air in it. At speed, it may be held back so that it pulls the cable taught, while at low speed it might be dangling loose just enough to bounce against the bottom of the truck and make a noise. It's easy enough to eliminate this as a possible cause by tightening the spare wheel winch until it clicks (you can't overtighten it, so no worries there). Check the pressure on the spare before you tighten it, too, so it'll be good and snug.
Old Jun 14, 2013 | 08:01 AM
trillosautodetailing's Avatar
Default tiny clunk from rear
i know this post is fairly old but i figures i would share my knowledge, my father in-law and i crawled under my wife's 2007 aspen because it had the same noise that you are describing and we cam to the conclusion it is the upper spring isolautor which is a dealer part only but run about $12 each which isn't bad hope this helps!
HowieF16
Oct 13, 2014 03:49 PM
BenjaminA
Jan 10, 2012 04:14 PM
moparrh
Aug 16, 2011 08:51 PM
greenstein8
Oct 4, 2009 09:16 PM
thunder-downunder
Apr 16, 2009 06:29 PM
