radio antenna location
I am in the process of installing an XM (Audiovox) receiver in my 2006 Crossfire coupe. I am trying to locate the radio antenna. I believe it is in the top of the rear hatch window glass. I have a surface mount connector that needs to be installed on the glass under the antenna wire. Can some one confirm the correct location of the antenna. A drawing or sketck would help. I don't wan to mount it on the defroster wire.
Antenna module is in upper right area of lift gate. The antenna is located across the inside surface of the lift gate. These can get scratched and cause you to have poor reception. The D.. service manual says you could repair this using window defogger repair kit. I would post pictures but fear I'd be doing so illegally.
Jceop
Aug 15, 2014 12:44 PM
