04 high rpm's at startup
Old Dec 13, 2016 | 11:53 AM
RPalmer's Avatar
Default 04 high rpm's at startup
Hello all. I'm having an issue with my 04 revving to the point it sounds like it is hitting a limiter. I just recently replaced a bad thermostat and the speed control servo vacuum line which broke during that goat rodeo. Could the new issue be a result of the engine overheating? Lost for ideas here, hoping somebody could point me in the right direction.
Old Dec 13, 2016 | 04:50 PM
FIREM's Avatar
Most likely a vacuum leak. Recheck that new line and others would be a good start.
Old Dec 14, 2016 | 12:25 PM
RPalmer's Avatar
I have checked all vacuum lines and they are good, but did notice that the throttle cable to the speed control servo moved freely. Could this be a problem?
Old Dec 14, 2016 | 12:59 PM
user97's Avatar
That is normal (servo cable moving) -- it is meant to have some slack...
Think about all of the things you have disturbed in the process of getting to the t-stat and check them.
mrfixit454
May 10, 2017 09:14 AM
ssaspen08
Mar 13, 2016 09:45 AM
jbauman
Dec 15, 2008 04:17 PM
jbauman
Dec 14, 2008 09:53 PM
ThunderRam
May 21, 2008 07:58 AM
