04 Pacifica- Thermostat and related problems
Old Jun 24, 2020 | 06:10 PM
Jamiejeimi's Avatar
Default 04 Pacifica- Thermostat and related problems
Hi everyone!
First, my car engine is 3.5L, 24valve, 6cyl.
Some back story: I'd needed to replace my thermostat for a while, but had no issues with overheating (just car taking forever to heat up over the winter), so I didn't bother. Recently, car overheated, so changed the thermostat once it happened.
My 18 year old son changed the thermostat on my car since I can no longer do repairs myself due to health problems. It was definitely bad, as it had a broken metal part where the spring slides into. There was a visible leak from the thermostat housing afterwards because he didn't notice/remove the old gasket and I also questioned if he had it in backwards, which he determined that he did, so flipped it around, removed old gasket and added new gasket and sealant. I had back surgery recently, so I wasn't able to make it outside before he finished the job to check for myself. After that, and losing the fluid from replacing/reorienting it a second time, I topped the fluid, but it never receded. I thought it might if I drove it a little, but it's still absolutely full and still overheats. I'm not sure if the thermostat is in fact backwards now, and if that could keep fluid from cycling through or what...? So,
Is my new thermostat possibly backwards? Can it being reversed cause overheating/prevent fluid from cycling through? And thanks in advance
Old Jun 26, 2020 | 07:51 AM
djetelina's Avatar
Have R&R'd the coolant bunches of times on my Pac. Every time the coolant needed topping off w/ 1 pint to quart. Sadly it sounds like the thermo may be installed inside out. The 3.5 (as well as most all engines) require the spring/copper sensor thing to be installed toward the engine side. That to ensure the copper sensor is exposed directly to the outgoing hot water. Be gentle w/ the 3.5, it may handle some overheating but the alum block/heads are delicate.
Ziggar
Jan 19, 2013 06:15 AM
rookiemom
May 6, 2011 12:00 PM
rookiemom
May 2, 2011 12:17 AM
BEAST2011
Jan 30, 2011 08:04 PM
ContinentalCruise
Cirrus & Breeze
Sep 23, 2006 05:15 PM
