04 Pacifica wiring?
04 Pacifica simultaneously lost the dome light, rear wiper, and backup lights. Shop looked at it for 1/2 day with no result. Surely I am not the first one to have it happen. Anyone else run into this and solve it?
Key point is that 2 weeks prior I was stuck in so much snow that it pulled the front bumper when backing out and lower lights off. Had it replaced the lower fog lights not working now.
I just picked up my 05 Pacifica and I'm loving it, but I have the same problem as you with the rear wiper, reverse lights, and interior lights not working. I was wondering if you got the problem resolved and if so what was the issue? I pulled my BCM and checked the connections and opened the BCM and reheated all the solder connections to make sure none were cracked. The only thing I have found wrong so far is two heavy gauge wires running into the BCM that both were running only a little over 2 volts each but are supposed to be 12 volts. I haven't had time to problem solve the rest of the issue. Thanks for any help you may be able to offer.
spotmaticf
Jun 23, 2010 08:59 PM
Jeremy2005
Sep 1, 2005 01:30 AM
