05 pacifica headlight problem
Old Nov 24, 2013 | 09:23 AM
kmc90's Avatar
Default 05 pacifica headlight problem
My 05 pacifica driver side low beam is out. I researched this problem and seems to be a common issue with this model. I have minimually pulled it apart and found that both high beams and the passenger low beam are recieving 12v under load but the driver side low beam is recieving only 4v. Any suggestions? Has anyone fixed this problem by themselves? I am planing on tracing the (4v) wires back to a common connection to look for a bad splice. I would think it's a bad ground but that would mean all the lights would be recieving low voltage.
Thanks in advance for your help
Old Nov 24, 2013 | 03:46 PM
TIPM is more then likely the issue. a bad splice will not drop the voltage it will still be 12v no matter how many wires are broken in the strain U will loose amps with less wires in the strain. Bad ground would send the voltage else where to ground and the bulb would be dim.
Old Nov 24, 2013 | 05:30 PM
kmc90's Avatar
Default Tipm
First, thanks for your help.
Would I need to replace the whole TIPM or the relay associated with that lamp?
Old Nov 24, 2013 | 09:59 PM
no relay for it the whole TIPM
kdagenais
Jan 6, 2013 08:22 PM
edwianni1
Jul 3, 2011 07:28 PM
wizzylizzy
Oct 14, 2010 08:09 AM
martywj
Jun 21, 2010 10:33 AM
madmac
Dec 10, 2008 12:51 PM
