05 pacifica no horn
Old Feb 14, 2019 | 02:52 PM
Mr.got's Avatar
Default 05 pacifica no horn
I thought it would be the clockspring, but everything else on steering wheel works. Only non function is the horn, any ideas
Old Feb 14, 2019 | 03:19 PM
REBEL59's Avatar
At least you were thinking...But what have you checked/tested? How long has the horn not worked? Fuse, relay horns themselves??????
Old Feb 14, 2019 | 03:30 PM
Mr.got's Avatar
This has been an issue for awhile (6+ months). I have not checked fuses or relays yet. Can't find fuse box or diagram of fuses to know which one.
Old Feb 18, 2019 | 08:23 PM
Mr.got's Avatar
so I've checked fuse and relays and those are good. How to check horn itself or even clockspring, if everything else on steering wheel is working?
Old Feb 18, 2019 | 11:33 PM
BiliTheAxe's Avatar
Testing the horn is easy.
1st: locate the horn.
2nd: disconnect wire/s from horn.
3rd: connect the horn directly to 12 volt source.
4th: if the horn scares the crap out of you when it makes noise, change pants.
5th: Connect volt meter to wire/s that were connected to the horn, and have someone try to sound the horn, look for signs of voltage reaching the horn.
Old Feb 27, 2019 | 11:03 AM
srp365's Avatar
I had an issue similar to this. Bad ground is what it turned out to be, search google for South Main Auto Pacifica and you'll see an issue Eric O tracked down to a bad ground under the battery.
Another electrical gremlin I had I traced back to a PAC Steering Wheel Control Interface for my Pioneer. Caused all sorts of grief.
flynavyj
9
Mar 29, 2023 04:20 PM
Bassturd
Sep 21, 2019 07:26 AM
Tim King
Cirrus & Breeze
Oct 30, 2014 11:37 PM
JohnnyD06
Jun 20, 2014 02:53 PM
sidhabo
Aug 21, 2009 12:53 PM
