06 Pacifica ABS light
Old Mar 8, 2009 | 08:37 PM
pearly28's Avatar
Default 06 Pacifica ABS light
I have a 06 pacifica and the ABS light is comming on. Every so often the brakes chatter and catch. I took it in and they said I needed a new left rear wheel bearing for $500. Does this sound right? Thanks in advance, Joyce
Old Mar 8, 2009 | 08:58 PM
nope u need wheel speed sensors not a wheel bearing and I would replace all of the sensors they have a bad habit of failing one after another the dealer has a TSB on this issue don't take it back to the people that told U that U need a wheel bearing.
Old Mar 23, 2009 | 05:50 AM
Thew1096's Avatar
Is the sensor connected to the bearing or is this something you can do in your garage? Everyone keeps telling me that the sensors are built into the bearing and both will need to be replaced. Is this true?
Old Mar 23, 2009 | 02:19 PM
not true the chrysler sensors are the sensors only U haft to take loose the hubs not replace them.
Old Mar 23, 2009 | 11:14 PM
Pacifica3.82007's Avatar
Are all model year Pacifica's affected by this? Something else fantastic to look forward to.
Old Mar 24, 2009 | 06:29 AM
Old Mar 24, 2009 | 07:55 AM
At last, something on my vehicle not covered by a tsb...
Old Mar 25, 2009 | 12:04 AM
if anything U want to have a tsb with that U know what the issue us and what it will take to fix it.
Old Mar 25, 2009 | 12:35 AM
chterryiv's Avatar
I had to have this replaced on right and left side of my 05' pacifica. Luckily i purchased extended warranty.
Old Mar 25, 2009 | 03:23 PM
True...
