06 Pacifica only blows air through defroster
Old Feb 22, 2015 | 12:07 PM
rob71's Avatar
Default 06 Pacifica only blows air through defroster
My 06 Pacifica blows air through the defroster vents only.I s this the actuator door that is causing this issue?Thanks in advance.
Old Feb 27, 2015 | 11:06 AM
scotrvmarine's Avatar
Check and clean your battery terminal and make sure they is absolutely no corrosion on the post and terminals. Then try to reset the system.
Turn on ignition switch to the on position. At the same time depress and hold the power and recirculation button on the A/C heater control for at least five second. The display will begin to flash when recalibration has begun. When the LEDs or graphics stop flashing the calibration is complete. If the flashing last longer than 20 seconds the there is a failure in the system which is beyond me.
This system is very voltage sensitive. Just a little corrosion on the battery messes with it.
Good luck and hope this works for you.
Old Feb 27, 2015 | 12:32 PM
ChryslerCACares's Avatar
rob71,
There could be a few things causing this this happen, have you tried scotrvmarine's suggestion?
This would certainly be worth bringing to the attention of your local Chrysler dealer.
jimG
Sep 5, 2014 09:20 PM
SupaDave
Apr 27, 2011 11:50 PM
bbatts
Apr 14, 2011 10:26 PM
havoc983
Aug 25, 2010 12:20 PM
nellis003
Jul 24, 2008 08:31 PM
